Phone number port.
Leo12
New Neighbour / Nouveau Voisin
@CS_Agent
I keep trying to submit a ticket but it won't work. I need my port out request to be processed
1 REPLY 1
@Leo12
You have submitted your port request with your new provider?  are you just not getting the porting authorization text?
Make sure your PM account is active and you can still receive incoming calls and text
Then call your new provider and ask them to re-trigger the porting request.
Wait another hour or two and you should receive that
If still not receive the text from PM asking you to approve the porting,  please open ticket with PM support using using direct message:
Make sure that you respond to this text within 90 minutes. If you do not receive this SMS or you do not respond within the 90 minute window, make up to 4 additional attempts to send it. If you are still experiencing any difficulties, reach out to a Customer Support Agent
(Ref: https://www.publicmobile.ca/en/on/get-help/articles/porting-out  )
