Phone not working
01-18-2022 05:13 PM
01-18-2022 08:56 PM
01-18-2022 07:21 PM
Indeed, @evrich
It's strange, however, sometimes rebooting a device (or toggling airplane mode on/off or resetting network connections), allows the device to refresh the connection to the network in ways which provide services wherein none existed before.
Don't really know why - but glad it worked.
01-18-2022 06:46 PM
glad to hear that,, and all working okay.
01-18-2022 06:35 PM
That’s what I did and voila. Calls are coming thto
01-18-2022 05:50 PM
Turned phone off and on. Talk started working. Hope it stays on🤞
01-18-2022 05:40 PM - edited 01-18-2022 05:43 PM
This replying to the OP
Edit: I dunno. Oracles...help yourself. OP, sorry to clutter your thread and send you all those useless notifications. I was just observing something different and so wanted to explore it.
01-18-2022 05:39 PM
This is clicking in the box below and click whir buzz I'm in this reply box and click Reply lower down
01-18-2022 05:38 PM
This is the reply button of this most recent post from darlicious.
01-18-2022 05:36 PM
@Anonymous
I had not even noticed that difference....
01-18-2022 05:34 PM - edited 01-18-2022 05:35 PM
Interesting. I use All Posts. When someone clicks on the Reply button of a post, the reply indicator will show and the subject line will include RE:. When someone clicks on the bottom main Reply button, the subject line does not include RE: and of course no indicator.
Just observations.
Edit: mmm...nope. hmmm. Why do a couple replies from darlicious not have the RE:?
01-18-2022 05:32 PM
@Anonymous
I needed an intro...
01-18-2022 05:29 PM
@darlicious : ...IOW... 🙂
01-18-2022 05:27 PM
If you have two US roaming add ons with a talk feature they will cancel each other out and cause calls to drop.
Here is some info about US roaming add ons that should help you.....
- While you have to have an active plan to purchase and use US roaming add ons the type of plan you have does not affect the roaming add ons features.
- US roaming add ons start the moment you confirm and submit your purchase in your self serve account and expire 240 hours later (10 days×24 hours).
- You can pre-load the funds needed to purchase the add ons in your self serve account so you only have to log in, select the US roaming add on and then confirm and submit your purchase.
- Wait til late as possible to purchase since they are immediately valid so on free wifi at the destination airport or stopping shortly before the border at mcd's or timmy's to buy the add on while on free wifi.
- If you are staying longer than 10 days you must wait a minimum of 24 hours to purchase the same US roaming add on or contact the moderators to add it before the waiting period ends.
- If you have two US roaming add ons with a talk feature that overlap the talk feature basically gets disabled. Avoid this....but you will have to get one removed by a moderator to get your calling feature back if this happens.
- After purchase reboot your phone and manually select either at&t or T-mobile to get better reception. Some areas have better coverage by either provider so when travelling around the US you will be better served by choosing the provider with better signal strength by locale.
- You will recieve incoming texts without any US roaming add ons. Adding the fongo app and textnow app for use on wifi are good to use for a back up plan or you could call forward your pm phone # to your fongo # before you leave Canada and purchase just the US data roaming add on. Fongo also works on mobile data (1 min=0.5mb/100 min=50mb) so you could still recieve incoming pm texts, recieve incoming pm calls to your fongo #/app, outgoing calls from your fongo number and outgoing texts from textnow for free or small fee from fongo.
- All US roaming add ons have either unlimted text, talk or both. Only data has limits depending on your purchase 250mb/500mb/1gb. Once the data is consumed it will just stop you could then purchase different roaming add on, wait 24 hr to buy or contact the moderator to buy the same US roaming add on again. (* except talk as previously mentioned.)
Happy travels and Stay--Safe!
01-18-2022 05:23 PM
From a Home screen, tap Settings Settings icon.
If an app isn't available on your Home screen, swipe left to access the App Library.
Tap Cellular .
Tap 'Cellular Network' or 'Network Selection'.
Tap the Automatic switch to turn off Switch off icon.
Once available networks appear, tap the desired carrier
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
01-18-2022 05:20 PM
Apple xr
01-18-2022 05:19 PM
01-18-2022 05:18 PM
Okay thanks
01-18-2022 05:17 PM - edited 01-18-2022 05:18 PM
@evrich : Is it possible you bought more than one add-on that had talk in it? Click on Plan Details and see how many lines mention talk. Multiples does not work. You'll need to get a CSA to fix that.
Contact a Customer Support Agent
01-18-2022 05:17 PM
I’ll try. How do you do that
01-18-2022 05:16 PM
Try manually selecting either of AT&T or T-Mobile, whichever works best for you,
01-18-2022 05:16 PM
Yes even earlier today
01-18-2022 05:15 PM - edited 01-18-2022 05:16 PM
01-18-2022 05:15 PM
Yes
01-18-2022 05:14 PM - edited 01-18-2022 05:14 PM
