02-01-2025 02:09 PM
02-01-2025 02:41 PM
@Rdfoot6508 if none of the suggestions offered here are helping then you will need to reach a support agent, it could be something on their end that they need to correct. Click the link below:
02-01-2025 02:32 PM - edited 02-01-2025 02:37 PM
@Rdfoot6508 wrote:I phone
Go into Settings and choose Cellular. Choose Cellular Data and then which line to use as your primary... and reboot
02-01-2025 02:29 PM
I phone
02-01-2025 02:24 PM
I did transfer an old number, tested. It worked fine. Got a text saying reboot phone to complete transfer and after that it didn’t work
02-01-2025 02:22 PM
@Rdfoot6508 did you try porting (transferring) in an old number you had with another company? If so, it likely has not completed. When did you try porting?
02-01-2025 02:20 PM
Canada, data working
02-01-2025 02:20 PM
@Rdfoot6508 wrote:Have rebooted no luck, I have an eSIM
Valid point. LOL. OK. Go into your settings and find the eSIM and make it your primary and then reboot. What phone do you have?
02-01-2025 02:19 PM
02-01-2025 02:17 PM
@Rdfoot6508 wrote:I am new, can’t dial out so 611 not an option
OK. So if you're new, have you tried rebooting the phone? Can you take out the SIM card and place it in a different phone? Sometimes a SIM card needs to be reprovisioned.
02-01-2025 02:16 PM
02-01-2025 02:15 PM
@Rdfoot6508 is text and data still working? Are you in Canada or in the US? Was your calling in/out working before? We need a bit more info to give you some suggestions
02-01-2025 02:14 PM
@Rdfoot6508 wrote:I can’t call or receive phone calls
Hey @Rdfoot6508
Can you share more information with us like.... are you new to public mobile or a long time customer? Have you tried dialing 611 to see if your account is paid up and active?
