05-31-2023 07:29 PM
I can't make outgoing calls says my number is not registered on the network systom and just renewed my service
05-31-2023 07:31 PM - edited 05-31-2023 07:31 PM
@Dannynight Can you try SIM card in another phone to test , and reset network settings and reboot the phone to start … forfurther help from support
05-31-2023 07:30 PM
HI @Dannynight yours is not a new activation?
on your phone, click Reset all networks
and Try your sim card in another phone
check if your phone connects to PM network
check if text and data work
if still unable to make calls, please submit ticket with CS agent at
