12-21-2022 11:04 AM
what is wrong. ive been using this phone and suddenly it wont connect to network
12-21-2022 12:03 PM
i just put the SIM in another phone and it say unregistered SIM
12-21-2022 11:50 AM
@Dave1960 was there any error message?
try to reboot your phone, and monitor the phone status. Does that show it connected briefly and then disconnected?
You said no outage, you meant you check your sim card in another phone and it works that is the best way to show if there is outage or not
12-21-2022 11:47 AM - edited 12-21-2022 11:48 AM
12-21-2022 11:38 AM
no same phone. i did take sim card out and re install
dont work
12-21-2022 11:17 AM
And the mentioned devicecheck?
12-21-2022 11:14 AM
no outage
12-21-2022 11:09 AM
Check to see if there is an outage in your area. Check outage map:
12-21-2022 11:06 AM - edited 12-21-2022 11:07 AM
Did you recently buy this as a used phone ?....https://www.devicecheck.ca/check-status-device-canada/
Try taking sim outta phone, then re install.
