06-13-2022 08:42 PM
1. I have autopayment setup
2. I just added 100$ into the account
3. Phone is still showing no service. What is going on please?
It says on my account that the next payment is on July 13 so I know everything is setup perfectly. This is my Moms phone I have setup so I need it to work!
437-345-4800
If the phone cannot work, I need a full refund ! this is ridiculous!
06-13-2022 09:38 PM
@canadaamz how long you have this phone for? did you buy it off from private sell?
If you still seeing no bars on your phone and it is not connected to PM, check if you phone is blacklisted here.
06-13-2022 09:34 PM
Reinsert SIM card and reboot.
Any bars?
And is Public Mobile scrolling on left top of screen?
Try sim in another unlocked phone.
I am thinking it is a phone issue.
06-13-2022 09:27 PM
HI @canadaamz if account is active, it should work, but it still not working?
what is the phone status? is it showing it connects to Public Mobile with some signal bars?
06-13-2022 09:26 PM
Account is Active
06-13-2022 09:25 PM
I bought the phone from Public Mobile ...(Telus)
06-13-2022 09:00 PM - edited 06-13-2022 09:00 PM
@MrSpock wrote:@canadaamz hi can you go into her account to see if there is a reactivate button if so press it reboot phone
What is the “Account Status” of the account when you logon?
Does it say active?
06-13-2022 08:55 PM
@canadaamz - we are customers and members like you here, not public mobile representatives and there should be no personal information posted here. Please, it is not recommended you post your phone number.
So, did the reboot work? Because it sounds like it didn't, and maybe you choose that solution in error?
Is this a new activation?
Can you try
Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
06-13-2022 08:49 PM
I did but no luck! still same msg
06-13-2022 08:47 PM
06-13-2022 08:46 PM
@canadaamz Remove the phone number. this is a public forum and you want to protect yourself by hiding your phone number. Click on the down arrow and Edit message
first question, you added $100 in the account, do you see $100 showing up as Available Fund? If you do, then the fund is there , just not used for renewal. try the Lost/Stolen trick to force a renewal
06-13-2022 08:45 PM
