Phone is disconacted
Habu
I can not make a call or receive. Would you please help. Thank you
1 REPLY 1
@Habu
first , please Login My Account again using incognito mode to confirm your account status, check if your account is Active or supsended
If active, good.  Try to change the Preferred network type or network mode to 3G Only and see if it fixes the issue
Let us know
