12-04-2022 10:43 AM
I can call out but not receive calls? Just activated SIM card
My Account
07-17-2024 03:38 PM
Can you send me the number? I think I missed that step.
12-04-2022 10:58 AM
Did you port your number and follow procedure? Leave old SIM in a phone, reply Yes within 90 min?
12-04-2022 10:52 AM
did you request porting in your number?
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins. If you are not receiving calls and text on your PM sim card and can only make outgoing calls, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox. Check the envelope icon on top right. Call them and get it fixed
12-04-2022 10:49 AM - edited 12-04-2022 10:50 AM
Did your respond "YES" to the port authorization request? (if porting from another provider)
Try rebooting and resetting network connections.
