10-29-2021 08:04 PM - edited 01-04-2022 05:19 AM
Phone will not do anything. I mean anything. The phone won't turn off turn on it won't get off the main screen. It's very hard to get anywhere.
10-29-2021 08:16 PM
10-29-2021 08:14 PM
If your device is frozen and unresponsive, press and hold the Power button and the Volume down button down simultaneously for more than 7 seconds to restart it.
for iphone
10-29-2021 08:14 PM
Do a hard reset.....google your phone model to find out how. If an iPhone google how to do a DFU.
10-29-2021 08:11 PM
With most phones you can perform a soft reset by holding down the power button and the volume down button until it turns off and you see the phones brand logo appear. Then let it power back on again.
10-29-2021 08:07 PM
@Ginny2437 tell us what kind of phone is that and will try to tell you how to reboot it.
