Phone does not receive incoming calls. The person calling has to call three times to get through.
10-14-2022
01:57 PM
10-14-2022
02:47 PM
computergeek541
I have been with Public Mobile for several years and never has a problem. Now people have to call three times to get through. My kids have the same issue with their public mobile plan as well.
Service
10-24-2022 04:25 PM
@GDTer iPhones behave that way when Do Not Disturb is activated.
10-14-2022 02:05 PM - edited 10-14-2022 02:06 PM
@GDTer hi go into your settings and maually select 3g it may help in the interim but
you need to contact a customer service agent to look into the issue
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
10-14-2022 02:05 PM
HI @GDTer it could be a 3G network issue where you are at now. If you go to a different area to test, you should be ok.
But what brand and model is your phone?
if it is a 3G network issue, it should be fixed eventually. But if you like, you can open ticket with PM CS agent and they can confirm if there is a known issue and reported
To open a ticket with PM CS Agent
at : https://publicmobile.ca/chatbot.
First type Contact CS Agent,
from the list of , choose "Other"
![](/skins/images/813D49D689E0D681E39391EAB60FD666/responsive_peak/images/icon_anonymous_message.png)
