Phone compatibility
_Niya_
when I go to check if my phone is compatible the option to choose the model and brand doesn't show up when I click the drop down button.
26 REPLIES 26
_Niya_
 @RossN Sorry nevermind it was Tellus
@_Niya_ it seems to me like your phone is locked to your previous carrier who was it?
_Niya_
@RossN I don't data, and even though i'm connected to Public Mobile i Can't send or receive messages or calls. They do work when I have wifi.
@_Niya_ it could be just a sim provision issue.  Open a ticket with PM support and they can quickly fix that for you
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
@_Niya_ so data with public or phone calls or regular texts don't work?
_Niya_
@softech it still didn't work
_Niya_
@RossN yes
@_Niya_ ok so just facetime phone calls and Imessages?
@_Niya_ try reboot, then try a network reset
if still fails, update your Carrier Profile
_Niya_
@softech its says I'm connected to public mobile
_Niya_
@RossN  I can only send and receive calls and texts when I'm connected to the WIFI
@_Niya_  any error showing on the phone?  like SIM not provisioned , No SIm, No Network?
@_Niya_ I am wondering if it is locked to another carrier does anything work at al?
@_Niya_ wrote:
What's a puk code?
_Niya_
@softech  my phone is not new and its not blacklisted
_Niya_
What's a puk code?
@_Niya_ do you have any messages on your phone like puk  code
Did the phone show SIM not provisioned?
is that a new phone you just got?  just for peace of mind , check if the phone is blacklisted
https://www.devicecheck.ca/check-status-device-canada/
_Niya_
I am new to public mobile
@_Niya_ so are you new to public or nothing works now that you swiched phones?
_Niya_
I have another Question. I am Unable to send and receive texts and calls.
_Niya_
Ok. Thankyou!
as long as it has been used in canada your good to go is it unlocked?
@_Niya_ iPhone 8 will work wirhout problem
_Niya_
It's an iphone 8
You should try clearing your browser's cache, or run the browser in incognito/privacy mode.
RossN
@_Niya_ hi yes that function hasn't been working for a while, what type of phone is it?
