05-15-2022 02:52 PM
I would like to know if these frequencies are supported on your network.
GSM: B2/3/5/8
WCDMA: B1/2/4/5/8
LTE-FDD: 1/2/3/4/5/7/8/12/17/19/20/28A/28B
05-25-2022 02:32 PM
Anything put in the phones category can still get tagged.
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-25-2022 12:31 PM
@Luddite?? I made a permalink to one of the posts and it works. sheytoon would need to take the time to edit the links. I'm sure he has better things to do.
05-25-2022 11:39 AM
@dust2dust "your amazing references need proper permalink links."
just tried, no luck. Guess not allowed for old posts. 😩
05-15-2022 09:34 PM
Thanks @dust2dust!
05-15-2022 06:49 PM
Use this tag... sheytoonbandz
05-15-2022 02:58 PM - edited 05-15-2022 03:00 PM
WCDMA: 2, 5 required for voice, also does data and text.
LTE-FDD: minimum required 4 and 12, does data and text but not voice.
@sheytoon - your amazing references need proper permalink links.
05-15-2022 02:57 PM
