Phone calls
Ta33
I cannot receive or make phone calls
2 REPLIES 2
hairbag1
@Ta33
what province are you in and what make/model is your cell ? Does data and text still work. If they still work, you could be experiencing issue with lack of VoLTE on your cell.  Here's some reading and a device checker at the end of the article...
https://www.publicmobile.ca/en/get-help/articles/volte
https://www.publicmobile.ca/en/get-help/articles/850-turndown
hi @Ta33
new subscriber or you have been with PM doe sometime?
first remove the old carrier sim card,  or if it the old carrier sim is esim, disable it from Sim Manager or Settings->Cellular
Then put the PM sim card in the phone, or if eSIM, you should be good
Next,  go to Sim Manager or Settings->Cellular and check if PM sim is showing there.  Make sure the Public Mobile sim is enabled , or Turn on this line  option is toggled on.  Also, change the label to Primary
Reboot your phone and Reset network settings and test and confirm if all work or let us know of if any the following does not work: inbound and outbound calls, inbound and outbound text, mobile data.
if the sim not connecting, ask PM support agent to help.  You can submit  ticket by direct message:
