Phone calls
SusanK2024
Despite having activated my account on Saturday, I cannot receive or make any Telephone calls… is this normal?
13 REPLIES 13
self solution removed
@SusanK2024
I think that @Phil_Adelphus initially suggested putting the PM sim in your phone...you might wanna edit your SOLUTION and provide it to him...I'm sure it would make him happy to know you got it going with his suggestion.  Welcome to PM.
SusanK2024
 When I transferred it all on Saturday, it said wait for a message saying to insert my new SIM card.  I never got a message saying that.  Suddenly dawns on me that I hadn’t put the new SIM card in yet. Have just done that… all working just fine now!  Sorry for not realizing sooner…Thank you so much for all your replies!
@SusanK2024   The number for support is only for issues with transferring your number to Public Mobile from a previous provider.  Since you can't call out or use data they may not be able to help in which case you need to contact customer support either by submitting a ticket at the chat/message icon bottom right of this page or send agents a private message using this link if the chatbot doesn't work.
hi @SusanK2024 I sent you number to porting team already. Please check your community inbox here
SusanK2024
Please send the number for support?
SusanK2024
SIM card is in correctly.  Says “call failed” when dialing from my “contacts”.  When inputting the same number, manually, same response
SusanK2024
Thanx… data not working… cellular data is enabled… I have rebooted my phone.  (didn’t know I was supposed to do that but done now)
@SusanK2024   You can tell if data is working by turning off wifi and trying to Google something.  You also have to have cellular data enabled on the phone if it isn't already.
Phil_Adelphus
@SusanK2024   From your previous post, it is a physical sim card you have.  Did you reboot the phone after you had activated the account and after inserting the sim card?  Is the sim card the right way up?  Is the phone giving you any kind of message, like "no service" or "SOS"?
SusanK2024
Texting works… not sure how I know if Data working?  Cannot dial 611. Doesn’t work. Will try rebooting my phone.
HALIMACS
@SusanK2024
can you advise if texting or data works?
sometimes easy fixes include rebooting your device, resetting network connections, or toggling airplane mode on and off.
when you dial 611 from the device, what messaging do you hear about the account status?
you might also want to troubleshoot the Sim card in another device, if it’s not an eSIM you’re using.
hi @SusanK2024 you ported the number??
sound like the number not ported yet.  But check with PM porting support team and confirm.   I will send you the number to PM Porting support team  Please check your community inbox
