10-22-2025
10:21 AM
10-22-2025
03:28 PM
computergeek541
Hi, I joined yesterday and my phone still doesn't receive or make calls or emails. I've been getting a message that says SIM1 not provisioned
10-22-2025 10:30 AM
Hello @ Honse,
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
10-22-2025 10:25 AM
look like the sim was not properly permissioned. Easy fix for PM CS agent,
I have escalated your ticket on your behalf. PM support will reach out to your via Community inbox. Please monitor here for their reply:
In the mean time, make sure you remove the old sim card , and disable old eSIM. PM sim card/eSIM should be the only showing on the SIM Manager or Settings->Cellular, and set as Primary. Reset Network Settings and check if it helps
