2 hours ago
Found the phone I've wanted, but, it's an "international" type phone out of China.
They sent these bands/frequencies that their phone works on.
Will this work with PM in Nova Scotia ?
Frequency:
2G GSM(3/8)
3G WCDMA(BAND1/5/8)
4G FDD(BAND1/B3/B5/B7/B8)
4G TDD(B38/B39/B40/B41)
Thank you for any help.
Supposedly they don't work in the USA, only certain spots, but Canada is supposed to be ok.
an hour ago
Hi. Thanks.
I was afraid it wouldnt work...
It's the only model i can find in the bar style with a touchscreen top 8(
an hour ago
@JimgB wrote:Hi. So, VoLTE not a good thing?
Many thanks
---ps--- this is a Qin F21 Pro phone. It's a thin Bar phone with a 2.8 or 3.5" Touchscreen with a push-button number pad below.
Having VoLTE capability is a good thing. The phoen that you were looking at won't be able to use the function. That's not a phone that should be purchased to use at Public Mobile. Please select a different phone device model.
2 hours ago
Many thanks
2 hours ago - last edited 2 hours ago
Enter the make and model of your phones.
https://www.kimovil.com/en/frequency-checker/CA
You need 2 frequencies for have good network connections.
@JimgB wrote:Will this work with PM in Nova Scotia ?
Frequency:
2G GSM(3/8)
3G WCDMA(BAND1/5/8)
This phone might work in some places that you go, but I strongly advise against purchasing this phone. The lack of band 2 on HSPA means that you will almost certainly not get any voice/phone call service in many places. Also, this phone is going to work on VoLTE at Public Mobile. On the LTE network, band 2 and band 4 are important. In short, this is a bad choice to try to use at Public Mobile.
2 hours ago
Forgot to say, I want 4G to work.
Thanks
