Compatibility please help.
SynnSalvator
Hello, I'm having a hard time following the compatibility chart as it's in mhz but phone look up isn't listed that way. I've been to komvili (probably spelt wrong) but the phone model code isn't in the  list of model codes..  So I figured I'd ask here.
Does anyone know if a Samsung A53 5g SM-A536W is 100% compatible with public bands?
Sons phone was stolen 2 months ago so looking at buying this as a replacement before he loses his account. Thanks for the help in advance!
2 REPLIES 2
@hTideGnow wrote:
HI @SynnSalvator
yes, A53 will work.  Better to buy the Canadian version to be safe
The SM-A536W being asked about is the Canadian version as indicated by the W.
HI @SynnSalvator
