Wednesday
We have very poor cell coverage at our summer home at S.V. of Island Lake, Alberta. You have to walk out onto the road to get a connection. Seems to be an issue with many of the residents there. Can something be done?
Thursday
Thanks for all the advice folks! I will switch to roaming and tech support refreshed my sim data. Fingers c
Wednesday
No charge for roaming if you are in Canada. It searches for the strongest signals from Telus or Bell cell towers where you are located.
You will need to purchase USA roaming for the phone to work in the USA…so no worries. Your phone will not work if you don’t purchase US Roaming.
Wednesday
The nice thing about PM is that it's a prepaid service meaning you will not get charged extra so no need to worry about roaming charges
Wednesday
HI @Mark59
if it shows EXT, you can try connect with Roaming enabled and it is free
and PM is prepaid, you have to buy before you use. If you can use it, it means it is included
Wednesday
Yeah...
Wednesday
I'm set to LTE, 4G, 3G
Wednesday
I've seen that. Yes, I believe you are correct, just hoping there's a fix.
Wednesday
Aren't there extra charges for roaming?
Wednesday
If coverage shows that it is OK then make sure the Roaming setting is enabled.
Wednesday
@Mark59 , this is the cell map for Island lake. This will give you an idea how far away you are from the local towers. Even though a carrier might say an area is covered, coverage holes are possible when tower density is low.
Wednesday
people on Telus and Bell both have the same problem??
try manually choose 5G and 4G or 3G?? check each one and maybe one is better
Wednesday
Yes but when I enter the location on the coverage map it shows full coverage
Wednesday
There's not much that can be done with poor coverage in rural areas.
