Add one not working
Kaity24
I added on minutes to make calls to the US, but they are not working. What can I do to fix this?
@Kaity24  First ensure your got the correct add on . That you got US long distance mins and not US roaming add on . Also reboot  your phone and try . But if you got wrong add on ask support to reverse it for you
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send  direct  private message to support .
send  a  private message   To CS_Agent
Sansan
@Kaity24  which add-on did you purchase?
Restart your phone and try again.
EB0
@Kaity24
Can you confirm that you have purchased the right add-on?
It’s suppose to say 1000 U.S long distance minutes $15
