3 hours ago
Signed up, installed esim. Now number not working, can't sign into the account because it's trying to text to a number I can't access. Any ideas?
3 hours ago
@Melinda999 I'm going to send you a personal message with the number to call for porting issues since it sounds like something is not right. Have a look in the top right corner of the screen, there's an icon of an envelop where your messages will be
3 hours ago
It's been 2 days. I did get the transfer text.
3 hours ago
@Melinda999that should be a good sign so far. Did you set up your account with a new number or did you transfer your number in from an old provider? If you transferred in, how long has it been AND did you receive a text from the old provider asking for you to confirm transferring the number?
3 hours ago
It does say esim and public mobile. How do I tell if it's active?
3 hours ago
@Melinda999 can you go into the Cellular section under setting to see if there is an eSIM and that it's active?
3 hours ago
No, it can't do anything
3 hours ago
@Melinda999 can the phone call out, receive calls, send/receive text, and does data work (if you are on a data plan)?
3 hours ago
I don't get the option to send to email. I saw that I'm supposed to get that but it just sendsnto text again with no email option
3 hours ago
I don't know much about esim but under where you enter the code you will see did not hey code. Click on that and you can get the 2fa sent to your email
3 hours ago - last edited 3 hours ago
@Melinda999 are you able to click on a link that says "Didn't get code"? If you see it you should be able to click on and select to send the verification number to email
