02-04-2026
11:27 AM
02-04-2026
01:48 PM
computergeek541
Received email from the other service provider saying transfer was confirmed, but message from Public Mobile says account number provided was not correct, and then no further instructions. How can I check the status of the transfer?
02-04-2026 01:48 PM
I did provide the account number. Will try the assistance team, thanks!
02-04-2026 11:35 AM
If you used IMEI to request porting, that could be the reason of the issue. Give the old provider account number instead.
there is a porting assistance team you can call and confirm what was wrong. I can't post the number here, but I will message the number to your community inbox. Please check and call them
But if you cannot reach them or they said they cannot help, you will need to contact PM using this link
And CS_Agent will reply to your community inbox, check here:
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
