02-04-2026
01:58 PM
02-04-2026
02:15 PM
computergeek541
I have activated physical SIM last night, received an email that activation is successful, but call and data are not working at all.
I’ve already tried to turning off and on the phone multiple times and still not working.
02-04-2026 02:02 PM
you removed the old provider sim?
if you cannot even make calls and data does not work with only PM sim in the phone, it is a sim provisioning problem. Ask PM to check
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
