08-19-2021 11:04 PM - edited 01-06-2022 03:12 AM
Can anyone tell me if a "Plum Ram8" cell phone will work on Public Mobile network before I buy one please ?
08-20-2021 01:57 AM - edited 08-20-2021 02:04 AM
Maybe you should consider the reconditioned market. The Samsung rugby a solid smartphone at $50 to $80 and fully compatible with public mobile...
https://recy-cell.ca/en/buy/samsung-galaxy-rugby-lte-8gb-sgh-i547m-black-unlocked-710/
Samsung SGH-414M Flip phone 26G/3G......$55
https://recy-cell.ca/en/buy/samsung-sgh-c414m-black-unlocked-810/
Or the Sonim XP-5 now that's a rugged phone! 2G/3G/4G $75-$95
https://recy-cell.ca/en/buy/sonim-xp5-black-unlocked-7-10/
08-20-2021 01:48 AM
The phone is 2G/3G only. Functionality is not great. You may have an issue editing the APN for MMS. Battery life is not terribly good. The reviews are terrible....
What are you looking for ? A rugged flip phone? There are better options.
Frequencies:
NETWORK
| Technology | GSM / HSPA |
| 2G bands | GSM 850 / 900 / 1800 / 1900 - SIM 1 & SIM 2 |
| 3G bands | HSDPA 850 / 1900 / 2100 |
| Speed | HSPA 21.1/5.76 Mbps |
08-19-2021 11:24 PM - edited 08-19-2021 11:25 PM
@BamaMan66 unlocked is good. .but the main issue is the bands.
honest, these smaller bands are pretty much unlocked for sure as they are not selling via carriers.
08-19-2021 11:23 PM
Yes it does state it is unlocked, and it is a brand new phone from Amazon. Thank you.
08-19-2021 11:19 PM - edited 08-19-2021 11:23 PM
very few information to this phone as to exact bands it carries
from Amazon.ca, some reviews did say that they tried in Telus and it works. So, it should
However, if you are buying new, check to see if you can return it just in case.
Just don't want to see you spent $100 and find it it doesn't work
08-19-2021 11:11 PM - edited 08-19-2021 11:25 PM
@BamaMan66 wrote:Can anyone tell me if a "Plum Ram8" cell phone will work on Public Mobile network before I buy one please ?
You'll want to double check with the manufactuer. The company's website advertises 4g frequencies of 850/1900/2100MHz but do not list any 3g frequencies. I believe that this company is simply referring to HSPA networks as "4g". If that's the case, yes, this phone will work at Public Mobile.
08-19-2021 11:08 PM - edited 08-19-2021 11:24 PM
@BamaMan66...make sure it's unlocked and note blacklisted or stolen. Should work on PM network just fine.
| 3G capabilities | UMTS 850, UMTS 1700, UMTS 1900 |
| 4G capabilities | LTE 700 (12, 13, 17, 4, 29), LTE 1700 (4, 66), LTE 1900 (2), LTE 2100 (4), LTE 2300 (40), LTE 2500 (7), LTE 2600 (7, 38), LTE 3500 (42) |
edit....your phone...
3G connectivity: HSDPA 850 / 1900 / 2100
4G / LTE connectivity:
