Phone Compatibility
evaaaambk
Is iphone xr compatible with public mobile? i already purchased a sim card so what do i do if my phone is not compatible?
Triguy
It should be compatible with PM.
https://m.gsmarena.com/apple_iphone_xr-9320.php
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).  band 12, band 5, band 2, band 1, band 4
  • HSPA: 850 MHz, 1900 MHz (UMTS).   B2, B5
yes, it will..
in case you need the APN setting.. here you are:
Public Mobile APN settings for Apple iPhone XR - APN Settings Canada (gishan.net)
(although.. it should be automatic.. just in case you need)
cellphoneuser1
@evaaaambk Public Mobile uses the Telus network. The network types are mostly the same as Rogers and Bell.  If a phone works on 3g on any of these network, it works at Public.
LovesToPM
Hi @evaaaambk
Yes it is fully compatible with PM.
One can check here: https://www.publicmobile.ca/en/on/get-started
