03-26-2022 05:05 PM
I'm trying to check for phone compatibility here (https://www.publicmobile.ca/en/ab/get-started), but when I try to expand the Phone brand option, the list is empty. Is there another way to check for compatibility? I have an iPhone 6S and iPhone SE 1st Generation.
Thanks! 🙂
05-20-2022 06:33 PM
FWIW the phone compatibility page still isn't working -- just tried it on both Chrome and Safari... This glitch needs to be fixed -- I can't think of a better way to discourage potential customers who want to check things out first!
03-26-2022 07:34 PM
They both work.
We had 2 1st gen SE’s working
A 6S has SE guts.....so is same as an SE.
03-26-2022 05:41 PM
Hi @min3 that has been like this for couple days. Sometimes a clear cache or Incognito mode is all you need.
But again, all North American iPhones will work here
03-26-2022 05:28 PM
I wonder if the SE 1st gen and the 6S will last up to iOS 16?
03-26-2022 05:27 PM
Looks like there is a glitch in the system. Yes those 2 iPhones will definitely work on PM.
I have the SE 1st gen and 6S Plus that works.
03-26-2022 05:20 PM
It seems that many customers are having the same issue where it is not showing up at all. Looks like you are good on both fronts for the time being anyways.
03-26-2022 05:18 PM
@min3 wrote:I'm trying to check for phone compatibility here (https://www.publicmobile.ca/en/ab/get-started), but when I try to expand the Phone brand option, the list is empty. Is there another way to check for compatibility? I have an iPhone 6S and iPhone SE 1st Generation.
A phone model doesn't have to be in the list to be compatible. It simply has to be unocked (or lcan be ocked to Telus in most cases), have a SIM card slot, and be able to connect to the network via the available network technology and frequencies. The above mentioned database will never be complete, and any list is also going to have some mistakes.
03-26-2022 05:15 PM
Thanks! 🙂
Both of those iPhones will work ....for now. They're both good phones, but are getting to the point where Apple no longer provides current updates to their operating systems.
I've had both iPhone SE (1st gen) and iPhone 6...they do work on PM network.
03-26-2022 05:10 PM - edited 03-26-2022 05:11 PM
@min3 yes, the compatibility check might not rendered well due to browser issue.
For both iPhone, they aree compatible with PM network so, go ahead
03-26-2022 05:09 PM
@min3 Both phones you listed will work Dont forget a referral code for $10 sign-up bonus. Welcome to Public Mobile!
