06-01-2023 10:38 AM
Hello,
I cant make a payment and renew my plan.
I register to pre authorized payment but i had to do it manually each month now nothing is working.
Can you please help?
Kind regards,
A.S
06-01-2023 12:08 PM
Thanks Community everything is working now... i was away and it was a security restriction from my bank.
I'm sorry for the inconvenience
have a nice day all💌
06-01-2023 12:03 PM
HI @Angela-jo all good 🙂
06-01-2023 12:02 PM
Im sorry for the inconvenience
06-01-2023 11:49 AM
Would be good to know what steps you took to fix the issue.
Did you find incorrect or incomplete credit card info ?
Let us know in case someone else reports similar problem.
06-01-2023 11:23 AM
HI @Angela-jo the payment here will fail, and once it failed, it takes long to fix. Honest, no one know why, even support sometimes not very helpful in this case
You are going to get a voucher to resume service first?
if not, you can try to update the CC and hope it works
06-01-2023 11:20 AM - edited 06-01-2023 11:22 AM
@Angela-jo wrote:i have a valid credit card registered with sufficient funds , card is not expired
rarely does Autopay fail...not every time.
If this has been happening ever since you started, I'd suggest you log in to your account and closely review the credit card info you entered on the account. Check the expiry date. Make sure you included all required info. Double check to make sure the cc account number is exactly right. Make sure the name on the credit card is correct. Make sure Subscribed is toggled on.
added pic
06-01-2023 10:56 AM
06-01-2023 10:54 AM
Double check to see if the Subscription button is enabled for automatic monthly renewal on your account.
Also, did you create the new Eversafe ID on the PM website or the new app to check your account?
The last suggestion if all fails us to contact a CS_Agent to see why you need to make a manual payment every 30 days when you are on AutoPay.
06-01-2023 10:52 AM
if this happens every time your subscription goes through the renewal process..something is wrong.
You might have a invalid credit card registered to your PM account. Or an expired credit card registered.
We can help you work through that issue if you're up to it. Let us know and we can assist.
06-01-2023 10:40 AM
Auto pay can fail
To make payment and reactivate plan .. if you know PIN number you can *611 with a voucher and *611 no PIN needed . You can also do this by by calling 18554PUBLIC . otherwise log into self serve make manual payment and reactivate service and or update credit card if necessary
