Payment
Karen17
How can I change my credit card number   the one that is registered in no longer valid
@Karen17 were you using Chatbot?  use 4 digit pin to validate instead ofy Account
or direct message PM support instead
Are you not able to login to your account?
I've had better luck with the pin verification option if you know your 4 digit account pin.
Karen17
Why can't I submit a ticket
dabr
@Karen17    You'll need to login to your self serve account and update the payment card by selecting Payment>Manage My Card.
Make sure to use incognito/private mode on the browser because of caching issues with the site or try another browser.  Desktop is also recommended for making any changes to the account.
