Payment
Aidan4342
My old visa debit card expired, so I went to update the info on my account and when I do it says the card is still expired and won't let me update it. Any help would be appreciated thanks
MrSpock
@Aidan4342 hello try to replace card instead of update see if that works
if that won't work  you need to contact a customer service agent, they will update it for you
you will need to open a ticket, to speak to a customer service agent    Click here you can check for a response in your community envelope top right corner next to your avatar, or if you are having issues with Simon you can send private message to a CS Agent here:  https://bit.ly/2GGCJzH
NDesai
@Aidan4342 Open the self-serve using incognito or private browsing mode and then try updating your card.
Timer
@Aidan4342
tried use browser from computer, clear cache and cookies and use one page inPrivate mode,
To Login Page
and go to payment,,, manage payment method and update card information and save payment.
you will get verification code by email or SMS
and inserting the 6 digit number and not press anything
just wait a 5 second automatically be login,,
