Payment
07-16-2022 09:48 AM
I have added 15.00 plan but now it says I have no more minutes ,,,help please
Payment
07-16-2022 11:53 AM
Why would you pay $15 to get 100 minutes when you can get 500min for $5? And they roll over....
07-16-2022 11:39 AM
Indeed, then as mentioned, the $5 500 minute add-on is excellent for limited minute plans. 1¢/minute for 8 1/3 hours of talking after your 1 2/3 hour plan.
07-16-2022 11:32 AM
hi @robb1334 did you put in the $15 thinking to renew earlier? if that is true, you have to open ticket with PM CS Agent. First check if you see $15 showing in Available Fund, then open ticket with CS agent
to open ticket with CS Agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
- start by typing : Contact CS Agent
- then Click "Contact Us"
- then Click "Other"
- finally Click "Click here to submit a ticket"
07-16-2022 11:32 AM
No I ran out of minutes I'm still on the same 15.00 plan but I can't change it immensely cuz I don't a change immensely option
07-16-2022 11:30 AM
I'm on the 15.00 plan as of couple months
07-16-2022 10:37 AM
Can you clarify what do you mean you 'added $15 plan'? Are you on $15 Plan or you downgraded it or...?
07-16-2022 10:36 AM
Just purchase the $5/500min add on. Its a one time purchase that rolls over every 30 days until completely consumed.
07-16-2022 10:12 AM
If you did a plan change to the $15 plan, plan change immediately OR schedule plan change on your next renewal date?.
Please not that PM is prepaid service. There is no refund of the remaining unused days of your current billing cycle.
07-16-2022 10:01 AM
@robb1334 you meant you changed to $15 plan? or you added some addon?
