08-27-2020 01:54 PM - edited 01-05-2022 03:40 PM
I have purchased 3 vouchers since yesterday and none of them have been accepted
Payment
08-27-2020 02:23 PM
@Andy9913 wrote:How do I submit to PM?
To submit a ticket to the Moderator Team, please start a conversation with the Public's virtual assistant, SIMon by clicking here or the icon (bottom right of your screen).
If you are still having problems contacting Public Mobile then click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
08-27-2020 02:21 PM
08-27-2020 02:16 PM
@Andy9913 Some vouchers can take hours to become active within Public's system so if you just keep trying every couple of hours and they should eventually get accepted. If by the end of day you can't enter them then submit a ticket to PM and include the 12 digit PIN numbers and they will enter them for you.
08-27-2020 02:04 PM - edited 09-06-2020 03:29 PM
@Andy9913 take snapshots of your vouchers, contact the moderators and ask them to add them for you. There are 2 ways to contact the Moderator Team:
- Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
- Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
08-27-2020 02:01 PM
Have called several times
08-27-2020 02:00 PM
yes , I have tried calling it in and doing online several times , even purchased another voucher incase that wouldn’t work.
08-27-2020 01:59 PM - edited 08-27-2020 02:00 PM
@Andy9913...
Try dialing 611 to get them applied to your account.
08-27-2020 01:58 PM
08-27-2020 01:55 PM
Hi @Andy9913 ,
Did you follow these steps:
https://www.publicmobile.ca/en/ns/get-help/articles/top-up-your-account
Payment voucher PINs are 12-digit numeric codes located on the receipt. The location of the PIN varies depending on where you purchase your voucher; however, you will typically find it on the top or the bottom of your receipt. To top up using a voucher, sign in to your Self-Serve account, select the ‘Payment’ tab, then ‘One Time Payment’. In the form on the next page, select ‘Payment Voucher’ as your payment method and enter your voucher code below, then click ‘Submit’.
