11-27-2024 02:29 PM
11-27-2024 02:33 PM
@pwradar51 .check credit card is one charge just pending ? If so it should fall off but if both charges are posted and the difference isn’t in your accounts available funds then message support to fix
submit ticket with support using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
11-27-2024 02:32 PM
Hey there, if you believe you were overcharged/double charged and need a refund, you will need to speak to a public mobile customer service agent directly for them to help you, you can message them here:
11-27-2024 02:32 PM
you can ask PM to check and issue refund.
Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
11-27-2024 02:32 PM
HI @pwradar51
you sure one of them not a pending charge only? If it is a pending charge, it will be dropped off after couple days
but if you are sure both are posted charges, check if the extra is showing up as a credit on My Account, Available Funds. If it is there, you can leave it there for next renewal
or if you want to ask support for refunds,
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
![](/skins/images/34AB3B0FE78BBE11DBF186F131BC3766/responsive_peak/images/icon_anonymous_message.png)
