01-17-2024 01:53 PM
Paid for $34 plan, was charged for it, went with esim for iPhone XR, can't access PM account, runs me in circles. Haven't heard from old service carrier if a request transfer was made for my #...
What am I missing here ?
01-17-2024 02:03 PM
@Leyton2 Did you leave old providers sim in the phone to reply YES to the confirmation text ?
I’ll send you the porting team number private message and they can re trigger the port request for you . Also check you phone setting sim manger and ensure the PM sim is enabled set to primary and “turn on this line “ is toggled on
01-17-2024 01:55 PM - edited 01-17-2024 01:55 PM
HI @Leyton2
did you use PM app to activate ? if you have not used it at all, your activation was not completed. You need to download the Public Mobile app from app store and continue the activation
if you already done using the app and request porting the number, you should get a text from your old service carrier. you didn't get it,so that is not good. You can call Public Mobile porting team to get status update. I will send you the porting team number. Please check your Community inbox for my message
