Payment issues
Ragini1
Hey, my credit card expired so I tried to pay my sim card payment with a voucher, but because the voucher was put in wrong too many times my account got locked. In addition, is there a way to put in a new 4-digit pin to set up a new credit card because I have forgotten my old one?
darlicious
@Ragini1
If you made more than 5 or 6 attempts it can get fraud locked at the account level. You can wait 24 hours and try again or contact customer support to remove the fraud lock. They can even add the voucher if you like....? You can reset you PIN # on your profile page in your self serve account. Here is some more info on your payment options with public mobile.
https://productioncommunity.publicmobile.ca/t5/Get-Support/Can-t-Make-a-Payment-or-Update-Your-Card-...
@Ragini1   You can change your four digit PIN by logging into your account and selecting Profile from left hand side of page and then update you PIN under My Security Info., as long as your account is not suspended.
Ragini1
Unfortunately it still doesn't allow be to use the voucher and the voucher was obtained in an ESSO gas stations
dust2dust
Wait about an hour and use 611. Be sure to use the proper 12 digit code. If there's more than 1 then use the one called PIN.
HI  @Ragini1   , usually you just have to wait an hour, or 2 hours, then you can try to enter it again
And where you got the voucher from?   Some vouchers need to wait 24 hours before they can be used, depends on where you got it from
