Payment failed!!??
Sashelle
What do I do?! I’ve tried 2 different cards, looked over everything, tried the app and the website and still!!! “Payment failed please try again with a different payment method”
Priority
Could this be an issue with the Postal Code + Billing Address by chance?
https://productioncommunity.publicmobile.ca/t5/Get-Support/Postal-Code-Issue/td-p/1040097
@Sashelle  To many failed attempts and you should wait one full hour before trying again and when you do try incognito mode private mode or use a different device . Clear app cache or un install it and re install see if that helps . If no luck use this direct link to support to help update for you
send a  private message   To CS_Agents click
Sashelle
I waited an hour already and it still never worked..and my postal code is correct
dust2dust
Wait an hour and try again. And only try twice per hour. Is it possible that your postal code is from a new area?
