01-03-2023 04:41 PM
01-04-2023 10:58 AM
Thank you for your help. The charges are real and not pending. I tried many times submitting a ticket, but my login won't work for that. But when I login the community my login works fine. Strange...
I was able to send a private message.
Thanks again
01-03-2023 10:42 PM
What does it say in your transactions?
On a credit card you can see a pending transaction and a final purchase. When purchase shows the pending disappears. If you have a balance because of a duplicate charge, which I doubt, your next payment will come from balance first.
01-03-2023 04:47 PM - edited 01-03-2023 04:49 PM
Before you proceed, @Nad939 , compare your credit card transactions (the ones which have settled/authorized, not just the 'pending' ones) against those within your self-serve account payment tab screen.
When accessing self-serve, be sure to do so incognito mode as the site has terrible caching issues resulting in out-dated information.
The other option is to tap the little refresher icons when on the self-serve landing screen.
EDIT: the only other thing i can think of is if you performed an 'immediate' plan change recently vs scheduling one on the 'next renewal'. This will create a whole other charge for a new 30 day cycle and the part remaining from the prior cycle is forfeited.
01-03-2023 04:47 PM
HI @Nad939 call your credit card and confirm if both charges are real charges. if they are both real charges, you can open ticket with PM CS agent and they can confirm why it happened and arrange for refund if eligible
You can open ticket with agent at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
01-03-2023 04:44 PM
@Nad939 did you check your Credit card and confirm if one of them is a pending charge only? Very likley just a pending charge. Many has this issue lately, the pending charge showing up on the credit card longer that it used to
Also, login My Account using Incognito mode and check Payment history page to confirm how many time PM charged you. Just in case it really charged twice, check if Available Fund has the extra charge. If it is there , it can stay there for use towards next renewal
