12-22-2022 09:27 PM
I'm going out of my mind trying to reset my password so I can reactivate my account I need help
01-01-2023 02:13 PM - edited 01-01-2023 02:21 PM
Not surprised that dealing with our buddy SIMon feels as though you're losing your mind. I find wearing the correct headgear, ignoring SIMon and just sending a private message helps.
Protection from SIMon's bad vibes
12-23-2022 05:34 AM
Are you using an email alias wth a plus sign (+) for your account? This can cause problems recieving the password reset email. Instead you can pay by pm payment vouchers via 611 or by calling 1 855 4PUBLIC and entering your 10 digit phone #. Or you can use the card on file if you know your 4 digit account PIN #. Once you reactivate your account you can reset your password by receiving the reset code via SMS text. This post gives you the alternative options for reactivating your account.
12-22-2022 11:58 PM
I had this issue before. cannot remember what eventually did it. but try a different device. or clear browser and restart device.
12-22-2022 09:36 PM
@Meanjean69 wrote:I'm going out of my mind trying to reset my password so I can reactivate my account I need help
Since PM website has caches issue, so clear caches , cookies then using computer and private or incognito mode browser to reset your password.
12-22-2022 09:36 PM
Hi @Meanjean69 did you try using Private/Incognito/secret mode to reset password and login My Account?
if it does not work, open ticket with CS agent
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
