04-04-2023 04:50 AM
This message comes up when I attempt resetting my password. “There was an error resetting your password. Please try again later.”
04-05-2023 02:07 PM
I am also getting this error today and have tried several times following the instructions very carefully.
Darlene
04-04-2023 03:11 PM - edited 04-04-2023 03:12 PM
Just very carefully try again later making sure that you follow instructions. Good luck.
04-04-2023 05:53 AM
@Darenwu pleas try ty again using Incgonito mode or try on another browser
if that still does not work, open ticket with PM support
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
