Unknown number/caller
04-05-2023 01:29 PM
I've been calling several landlines recently and the recipients tell me that I'm showing up as Unknown Caller (or Number). This started happening within the past several days, and before I switched my phones. They're all on Bell if that makes a difference. I've never had this problem before.
Service
04-05-2023 02:11 PM
This wasn't related to a phone setting change or anything on my end. My Galaxy S7 and S22 both had caller ID set to Network default and not hidden. Calling other people on their cell phones doesn't present a problem - my ID still goes through.
I don't know anyone not on a Bell landline service to call and check if it's potentially a Bell problem. Other names / numbers have shown properly on the recipient's phone, though, so that makes me think it might be Telus / PM-related.
04-05-2023 01:46 PM
@toast only Bell's subscriber not see your number?
Others see yours without problem?
Make sure you check your phone and you didn't enable hide my number option
iPhone
Open the Settings app and scroll down to tap on the Phone option.
Tap Show My Caller ID, then turn the toggle off to hide your number.
Android
Launch the Phone app and open the Menu in the top-right corner.
Go into Settings, then scroll down to Supplementary Services. Depending on your particular device, you may need to go to Calls > Additional Settings.
Tap Show my caller ID and choose to Hide number from the popup menu.
