03-28-2023 10:41 AM - last edited on 03-28-2023 03:18 PM by computergeek541
I have switched from bell to public mobile a couple months ago and ported my number over when my family members call me it goes straight to voicemail and it does not ring through.
04-05-2023 02:03 PM
still having this issue regretting every switching to public mobile. support tickets do not help
03-29-2023 04:33 PM
Still having issues submitted a ticket waitin on tech team
03-28-2023 11:07 AM
@Tycen wrote:Yes it is connected to PM network and has been since Feb 4th lol rebooting then trying the mobile data option Thanks
Has the calling feature ever worked? There have been hiccups with the calling feature here and there during the ongoing VoLTE rollout. You could potentially be impacted. It might be worthwhile initiating a support ticket using the chatbot link and having the account looked into.
03-28-2023 10:55 AM
03-28-2023 10:52 AM
Have a android not sure what FOCUS would be
03-28-2023 10:50 AM
Check your settings - had the same problem that turned out to be my iPhone's FOCUS settings.
03-28-2023 10:49 AM
@Tycen wrote:Yes This has all been done over a month ago. the port is completed.
so it wasn't port replated
is your data working? do you see your phone connected to PM network?
You could be impacted by the recent VoLTE enablement.
Try this first, power down the phone for 5 mins and power up again and test
If that still does not work, you might want to try to check if you have a VoLTE option under Connection->Mobile Data, enable it and test agian
if it still does not work, try to change the Preferred network type or Network mode to 3G only and see if incoming calls are working after
If nothing works, you might need to open ticket with PM support
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
03-28-2023 10:47 AM
03-28-2023 10:46 AM
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins. If you are not receiving calls and text on your PM sim card, and only outgoing calls, wok then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
03-28-2023 10:45 AM
@Tycen , it sounds like your number transfer did not complete. When you requested the number transfer, did you verify the transfer from the Bell end? Check your Bell account to see if it is still active which would be a good indicator of a failed number transfer. You will need to resubmit the number transfer in this case.
