11-09-2021 04:42 PM - edited 01-06-2022 03:59 AM
HI ya.
I have 2 issues.
I have lost my login password and was unable to answer a challenge question.
What would be my next step please.
11-11-2021 05:51 PM
@JAMAME903 wrote:I forgot my signing email to reset my self services account . When I used forgot the password/username but The email is not accepted. Plse help if anyone knows
you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
they can solve your issue, they are nice Service Team they will help you 100%.
and them will reset for you,
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
Good Luck..
11-11-2021 05:50 PM - edited 11-11-2021 05:51 PM
did you try to put in any email address you might have used? you can try as many time and see which email address will bring you to next step .
if you still unable to get the password reset using the Forgot Password link, you will have to open ticket with PM using the chatbot. click on the Bubble or directly at: https://publicmobile.ca/chatbot
Follow this to get to ticket open screen quicker:
11-11-2021 05:45 PM
11-10-2021 12:34 AM
difficult situation of no email and no answer to security question. One easy answer.. contact support agents. They will be able to help after verification of the account.
11-09-2021 09:35 PM
As noted by everyone, contact a PM CS Agent by clicking on the SIMon chat button and type in Create a Ticket.
PM is taken extra steps to prevent SIM swapping.
11-09-2021 05:37 PM
1. Open a ticket with CSA
2. After you get access to your account, Write down your email, password, and security answer and save them in secured place.
11-09-2021 05:26 PM
Hi @Herbach
Is there something we might be able to assist with, or do you require access to your self-serve to view usage/data/minute details or perform an account change or purchase?
11-09-2021 05:16 PM
@Herbach wrote:HI ya.
I have 2 issues.
If you're stuck with lost credentials, only way out is to ask CS for help:
11-09-2021 04:51 PM
Yes, the security question could be hard, but no worry, just open a ticket with PM and their support will sort this out with you.
At Chatbot, Follow the steps below and you can get to the ticket open screen quicker
11-09-2021 04:51 PM
@Herbach since yyou can not answer the challange questions the best way is to use the chat bot and submit a ticket to CSagents. using the chat bot will/should verify your account before submitting the ticket.
11-09-2021 04:48 PM - edited 11-09-2021 04:50 PM
you close all Browser and do clear cache and cookies for any Browser,
and try open one Browser incognito mode,
you can try Forgot your password visit Here link, and enter your email address,
and after login you can change your security question,
or you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
Good Luck...
