04-05-2023 06:24 AM
Password don't work and i can't reset it. Help. My daughter's phone broke. Im going to be paying for an account i can't use.
04-05-2023 12:13 PM
Passwords are case sensitive - since you know the password then make sure you pay attention to upper case and lower case letters.
04-05-2023 09:51 AM
The website is finicky.
You can try to login with a different web browser, clear cache or incognito mode. Or try a different device.
04-05-2023 06:26 AM - edited 04-05-2023 06:28 AM
if the phoen just 'broke" and not lost, take the sim card out from the boken phone and put it in another phone (like yours). Your can then login My Account by asking the 2FA code sent via SMS and you login My Account that way
But if phone was lost, no other way to get into email address, PM support will be your friend then, please open ticket with them
1. Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
