Add 2nd line
ash04
Hi,
 At present, I have public mobile plan since last 3 years.
I am planning to add 2nd line under same account.
1) is it feasible to add 2nd phone line ?
2) Is there any promotion or discounts can be added to both lines ?
My another question is,
1) What is the process to refer a friend?
     I can see the my personalized code under my account profile.
   However, just wondering what is the complete process from other party to ensure right steps has been followed. ?
Thanks
ShawnC13
@ash04 just to add to the information above, if you do get a second account you can refer that line so that you will get the credit for it as long as it is active!
hairbag1
@ash04
in addition to what's already been said...you can't use the same email address as the original account.
If original account uses a gmail account, then use alias...ie joeblow+1@gmail.
dust2dust
1. All accounts are individual. No second or family lines.
2. No. See above.
3. At the last page of activation there's a referral code box. Type in your referral code and click the add button and wait for the green check mark. Watch those zeros and ohs and ones and ells etc.
