Paid put Cannot log in
LandoBean
@CS_Agent
I paid for my subscription but when I was transferring my number, your system said it failed. And after that, my account was not able to be logged in. It shows Forbidden A1 for 5 days and no one is responding or helping from PM. I just want to login to my account and cancel your subscription!! This is so annoying !!!
2 REPLIES 2
fixin
@LandoBean - contact CS_Agent here:
⬇️ Click the link for an Agent * ⬇️
If the link above doesn’t work go here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours.  You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for an agent because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
If you want to continue porting click here as I will send you the porting team number: Messages
HI @LandoBean
so, you have no service yet?
here in the Community, we are just customers
please open proper ticket with PM CS agent for help.  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
