12-01-2020 06:43 PM - edited 01-05-2022 05:36 PM
Have never used the data on my phone ( old type Nokia Fold Flip ). Tried a few times for plain old web access but can’t get past the ‘subscribe to packet data first’. Any suggestions? Sorry if this has been asked before/any helpful PM threads?
Service
12-01-2020 08:00 PM
@Luddite thank you for the info. much appreciated
12-01-2020 07:59 PM
@RosieR We know thge phone works on PM for calls >> data will also work if APN can be configured.
FYI: Network Frequencies at PM
4G LTE/LTE Advanced: 700 MHz, 850 MHz, 1900 MHz; 2100 MHz downlink with 1700 MHz uplink (AWS). PM throttles speed on these to 3 mbps.
HSPA (3G): 850 MHz, 1900 MHz (UMTS). N.B. Must have these for calls to work. Texting and data also work on the 3G frequencies.
12-01-2020 07:47 PM
@Kez wrote:Would this also be the same for an LG f4nr flip phone? This one has an inbuilt browser button.
hi @Kez ok here goes...
- Nokia 3710 Fold - 3G - GSM - cellular phone. No, this doesn't work with Public Mobile. GSM usually means 2G service; Public Mobile is only 3G and LTE. The bands in use are the same as Telus as listed here: https://en.m.wikipedia.org/wiki/Telus_Mobility. If it's in the list, this website has been accurate: https://willmyphonework.net.
- Flip LG-C441 F4NR - Compatibility ? It should work since it has 3G 850/1900 which is what Public Mobile uses. Public Mobile uses the following frequency bands: 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
I hope this helps. Best wishes
12-01-2020 07:33 PM
Ok thanks. Looks a bit complicated but i’ll get too it. Thank you.
12-01-2020 07:26 PM
- Yes, that’s correct. So should data work?
12-01-2020 07:24 PM
Connectivity: Bluetooth, Packet Date, GPS, USB cable. Configuration: Default config sett. TELUS, ACT. def. in all apps. Preferred access pt. TELUS SP. Personal settings
12-01-2020 07:22 PM - edited 12-01-2020 07:28 PM
12-01-2020 07:21 PM - edited 12-01-2020 07:26 PM
@Kez wrote:That’s too bad. Put a lot of effort into getting this phone after seeing a YouTube video with a guy accessing the internet on it.
12-01-2020 07:18 PM
It's been a long time since I've used a flip phone, but can you elaborate on what settings are available for your phone to access data? Modern phones will configure APN, which is required for cellular internet connectivity.
12-01-2020 07:07 PM
12-01-2020 07:00 PM
12-01-2020 06:54 PM
12-01-2020 06:50 PM
The phone works as a phone and I can text/receive texts.
12-01-2020 06:49 PM
Nokia 3710 Fold
12-01-2020 06:49 PM
12-01-2020 06:45 PM - edited 12-01-2020 06:46 PM
@Kez wrote:Have never used the data on my phone ( old type Nokia Fold Flip ). Tried a few times for plain old web access but can’t get past the ‘subscribe to packet data first’. Any suggestions? Sorry if this has been asked before/any helpful PM threads?
@Kez hi what is the exact model of your phone? alot of the old flip phones won't work for data
