PUK
arielle13
Please I need to retrieve my PUK code
Dunkman
@arielle13
What message is being shown on your phone? There are different versions of PUK.
From a previous thread:
SIM network PIN blocked. Enter SIM network PUK."
- This is asking for Samsung's "master code" - I got this after entering the wrong code for the message below too many times. Samsung and/or your previous carrier can give you this.
"SIM network unlock PIN"
- This is asking for your previous carrier's unlock code - just contact them with your IMEI and they'll give it to you easy peasy. If you enter this incorrectly too many times, you'll get the error message above.
PIN unlock key (PUK) is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
    • If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
    • Once the PUK is recovered and validated, you will be asked to choose a new PIN.
Caution! If the PUK is entered incorrectly up to ten times in a row, the SIM card becomes unusable.
HALIMACS
@arielle13
The easiest way is to tap the link https://www.publicmobile.ca/en/on/chatbot then ask the SIMon chatbot just this:
"Need PUK"
Follow the precise directions it provides based on the PUK messaging your device is displaying.
@arielle13  If you need help from support here the links
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here
  • you can send a private message to our  CS_Agents by clicking here.
