01-05-2019 04:26 PM - edited 01-05-2022 06:26 AM
Anyone else out there that have needed a puk number I emailed the lm over 24 hours ago and haven't heard anything back yet
01-05-2019 09:54 PM
@Carld123 wrote:
If its a PUK code you need that needs to be recieved from PM..read in a similar thread the codes are all set by default to 1234...but as I said I read that ..not a guarantee..
The sim card security PIN is set to 1234 for Public Mobile sim cards unless someone changes it. I have actually tried the code.
Since the PUK is only needed if the sim card's secrurity PIN is entered too many times incorrectly, I'm kind of unsure why we see so many requests for the PUK code. I beleive that many, if not most, users usually just ignore these settings and never even bother enabling sim card secuirty in the first place.
01-05-2019 05:16 PM
01-05-2019 04:40 PM
Yes I have Samsung s7
01-05-2019 04:39 PM
@Mugfordmegan87 wrote:Anyone else out there that have needed a puk number I emailed the lm over 24 hours ago and haven't heard anything back yet
If it's a Samsung phone then I'm pretty sure they can supply it to you.
01-05-2019 04:29 PM
Thanks
01-05-2019 04:28 PM
@Mugfordmegan87, Moderator response time is curently (unfortunately) in the 2 -3 day range.
