10-08-2019 03:59 PM - edited 01-05-2022 07:28 AM
Does any one know what the email POP (NOT imap) settings are for:
Gmail....for iPad and iPhone
TELUS.....for iPad and iPhone.
I keep thinking I have the correct settings but keep seeing different ones to use and they mysteriously change. And when I do the settings and save, I go back, and the port settings change as does Authentication...I select password and go back and the setting disappears.
So frustrating.
10-09-2019 12:54 PM
@stonechucker wrote:Just curious why you're using POP for gmail.
@stonechucker me too. That's why I pointed out that ActiveSync is available, and included info on using it. Oh well, eh? ![]()
10-09-2019 08:30 AM
GMAIL
pop.gmail.com
Requires SSL: Yes
Port: 995
TELUS
pop.telus.net
Port 110
Authentication: Yes, Email account Username and Password
SSL/TLS: NO
10-09-2019 08:17 AM
10-08-2019 11:38 PM
I got Telus pop to work from instructions. Thanks
I got Gmail pop to work from instructions and a whole bunch of trial and error.
Where they ask for user name and password......do it TWICE! The second spot is where it says optional......put user name and password there as well....it is MANDATORY when using Apple mail.
THANKS.
10-08-2019 06:35 PM - edited 10-08-2019 06:37 PM
@srlawren wrote:@88cranston I'm not an iOS guy, but Gmail definitely (and Telus probably) supports Exchange ActiveSync, which is way better than POP/SMTP.
POP for Gmail:
https://support.google.com/mail/answer/7104828?hl=en
ActiveSync for Gmail:
https://www.lifewire.com/what-are-gmail-exchange-activesync-settings-1170851
Telus POP:
https://www.serversettings.email/telus.net-email-server-settings-pop.php
Telus mail config for iPhone/iPad:
https://www.telus.com/en/bc/support/article/set-up-email-iphone-ipad
Thank You!!!!
I had found those before. And the set up on both ipad and iphone actually "set up"...then some of the settings disappear. Been working all day on both.
Sooooooo if any one has got either Telus or a Gmail POP account set up sucessfully on a ipad or iphone, please let me know.
I have done it before but........
10-08-2019 04:07 PM
POP for Gmail:
Telus POP:
