3 weeks ago
3 weeks ago
Okay I talked to customer support and they have confirmed that I AM eligible for the bonus data with my 60G for 34 unlimited plan, and that the error message on desktop is nothing to worry about 😊
3 weeks ago
is yours a 5G unlimited plan? I think the unlimited speed at 512Kbps makes this 10GB incompatible.
But please ask PM to confirm. Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
3 weeks ago
HI @pjmorrow
someone else posted the same:
https://productioncommunity.publicmobile.ca/t5/Get-Support/PMDATA10-add-on-incompatible-with-34ULCW-...
did you click Find out Why?
but I suggest you check with PM support agent directly.. Please submit a ticket with CS Agent using Chatbot here:
Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
