PM use in US
Venu
Hi, planning a travel to US. Is there a way to use Public Mobile services?
DDM69
Just another thing to add…if you’re using an iPhone- iMessage uses data. If you turn iMessage off you can text without needing data.
Have a good trip!
hairbag1
As suggested above, there's a few available add-ons for travel to US. One thing...once you buy the add-on, it last for 240 hours so plan your purchase ahead of time.
Best practice is to load $$ in to Available Funds before you leave home, then when you get to first town with free wifi, log in to your PM account and select the add-on you want. Walmart and McD's all have free wifi in US.
You should be good to go...you might have to manually select either AT&T ot T-Mobile...whichever works best where you're at.
JL9
How long are you going, if longer than 10 days it may be more reliable and cost effective to go with a local prepaid option or a voip app. Also if you do the PM US roaming add-ons and finish up 10 days and want the exact same add on again, you will have to reach out to a CSA to get that added on immediately otherwise you have to wait 24 hours to manually do it yourself
Meow
Yes, you have to buy US add-on
US Roaming for 10 day packages
Unlimited U.S. Talk, Text and 250MB Data Bundle = $20
Unlimited U.S. Talk and Text Bundle = $15
Unlimited U.S. Talk Only = $8
Unlimited U.S. Text Only = $8
U.S. Data Only for 10 day packages
250MB = $10
500MB = $15
1GB = $20
You don't need to purchase US roaming text add-on to receive incoming texts while in US.
https://www.publicmobile.ca/en/bc/get-help/articles/us-roaming
Please note US add-on is valid for 10 days only and counter starts as soon as you purchase it. Then while in US you have to activate roaming and to connect to to AT&T or T-mobile.
@Venu   Yes, you can use it if you buy the Roaming add-on.  There are different ones but they all are 10 days in length.  So, if you go longer, you have to re-buy it after 10 days:
Here are the different US roaming options:
US Roaming
Bundle - US Roaming - Talk Text (10-day) - $15.00 (10 Reward points)
Bundle - US Roaming - Talk Text 250 Data (10-day) - $20.00 (15 Reward points)
Data - US Roaming - 1 GB Data (10-day) - $20.00 (15 Reward points)
Data - US Roaming - 250 MB Data (10-day) - $10.00 (5 Reward points)
Data - US Roaming - 500 MB Data (10-day) - $15.00 (10 Reward points)
Text - US Roaming - Unlimited Text (10-day) - $8.00 (5 Reward points)
Talk - US Roaming - Unlimited Talk (10-day) - $8.00 (5 Reward points)
