PM sending verification code to old number
Synnnnntax
PM is sending verification code to the old
original sim card number. However, I already did the transfer of number within 2 days of having it. Had no problem for the past 4 months. I just checked today to update my plan but I cannot log in. There’s no option to send code to email. HOW TO FRIKIN FIX THIS?????
1 REPLY 1
slusagm
Get the code via email first.  click didn't receive code or resend code and then choose email
if you can login, go to Profile -> Manage EverSafeID and change phone number
but if you cannot login , then ask PM to update it.   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
